Project CTC A13
Re: Project CTC A13
Bericht door Rob52 » 08 jun 2021, 14:13
Voordat je de krampen zoekt, het configuratiebestand zit in ....\BIGTREETECH-TouchScreenFirmware-master-10-03-21\BIGTREETECH-TouchScreenFirmware-master\TFT\src\User
Code: Selecteer alles
#ifndef _CONFIGURATION_H_
#define _CONFIGURATION_H_
#define CONFIG_VERSION 20210217
//============================= General Settings ============================
 * Screenshot for documentation
 * Long press touch screen capture the current full screen to SD card
 * Only for documentation purposes, DON'T enable it when normal printing.
//#define SCREEN_SHOT_TO_SD
 * Smart Home
 * If enabled, long press "Back" button triggers Home screen
 * It doesn't interfere with the "Screenshot" and "Marlin/Touch Mode" other than if
 * enabled, long press "Back" will not trigger "Screenshot" or "Marlin/Touch Mode"
#define SMART_HOME
// Enable Status Screen
// Enable this to show status screen as the default home screen. Disabling it will show a static menu.
#define ENABLE_STATUS_SCREEN true  // To enabled: true | To disabled: false (Default: true)
 * This setting determines the communication speed of the printer.
 * 250000 works in most cases, but you might try a lower speed if
 * you commonly experience drop-outs during host printing.
 * You may try up to 1000000 to speed up SD file transfer.
 * Options: [2400: 0, 9600: 1, 19200: 2, 38400: 3, 57600: 4, 115200: 5, 250000: 6, 500000: 7, 1000000: 8]
#define BAUDRATE 5  // Default: 5
 * Default Primary Language (for Touch-Mode only)
 * Select the language to display on the LCD while in Touch Mode.
 * NOTE: To add/flash a second language copy the required "language_xx.ini" file from
 *       "Language Packs" folder to the SD root folder. Then preset the reset button
 *       to load/flash the copied language file.
 * Options: ENGLISH,    CHINESE,  RUSSIAN,     JAPANESE,   ARMENIAN,  GERMAN,        CZECH,
 *          SPANISH,    FRENCH,   PORTUGUESE,  ITALIAN,    POLISH,    SLOVAK,        DUTCH,
 *          HUNGARIAN,  TURKISH,  GREEK,       SLOVENIAN,  CATALAN,   TRAD_CHINESE,  UKRAINIAN
#define DEFAULT_LANGUAGE ENGLISH  // Default: ENGLISH
 * Default Touch Mode Color Options
 * Options:  0: WHITE,      1: BLACK,       2: RED,      3: GREEN,     4: BLUE,   5: CYAN,
 *           6: MAGENTA,    7: YELLOW,      8: ORANGE,   9: PURPLE,   10: LIME,  11: BROWN,
 *          12: DARKBLUE,  13: DARKGREEN,  14: GRAY,    15: DARKGRAY
#define TITLE_BACKGROUND_COLOR      1  // Title background color (Default: 1)
#define BACKGROUND_COLOR            1  // Background color (Default: 1)
#define FONT_COLOR                  0  // Font foreground color (Default: 0)
#define REMINDER_FONT_COLOR         2  // Reminder font color, such as: "No print attached", "Busy processing", etc. (Default: 2)
#define VOLUME_REMINDER_FONT_COLOR  5  // Volume reminder font color, such as: "Card inserted", "Card removed" (Default: 5)
#define STATUS_XYZ_BG_COLOR        15  // Background color for X Y Z position display in Status Screen. (Default: 15)
#define LISTVIEW_BORDER_COLOR      15  // Border color in List view (Default: 15)
#define LISTVIEW_ICON_COLOR        15  // icon color in List view (Default: 15)
// Mesh Leveling Display Colors
// Set the colors used for drawing the mesh with the minimun and maximum value in the grid.
#define MESH_MIN_COLOR 7  // Default: 7
#define MESH_MAX_COLOR 2  // Default: 2
//=========================== Marlin Mode Settings ==========================
 * Default UI Mode
 * Mode switching is still possible by holding down the encorder for two seconds.
 * Options: MODE_MARLIN (Marlin Mode)
 *          MODE_SERIAL_TSC (Touch Mode)
#define DEFAULT_LCD_MODE MODE_MARLIN  // Default: MODE_SERIAL_TSC
 * Default Marlin Mode Background & Font Color Options
 * These colors can be changed in Touch mode, but can also be set here.
#define MARLIN_BKCOLOR 1  // Default: 1
#define MARLIN_FNCOLOR 0  // Default: 0
// Text displayed at the top of the TFT in Marlin Mode
#define MARLIN_BANNER_TEXT "Marlin Mode"  // Default: "Marlin Mode"
// Show banner text at the top of the TFT in Marlin Mode
#define MARLIN_SHOW_BANNER true  // To enabled: true | To disabled: false (Default: true)
 * Run Marlin Mode in Fullscreen
 * Options: 0: Disabled (RECOMMENDED FOR TFT24)
 *          1: Enabled
#define MARLIN_MODE_FULLSCREEN 0  // Default: 0
 * Keep Serial always On (ONLY SUPPORTED ON TFT24 V1.1, TFT35 V3.0, AND TFT28 V3.0)
 * Keep UART (Serial communication) alive in Marlin Mode.
 * Allow seamless OctoPrint UART connection to the TFT's UART/serial expansion port no matter which
 * mode the TFT is in.
 * Options: [0: Disabled, 1: Enabled]
#define SERIAL_ALWAYS_ON 1  // Default: 0
 * LCD/Touch Encoder
 * In case LCD/Touch Encoder's sliding buttons (pin LCD_ENCA_PIN and LCD_ENCB_PIN)
 * don't produce any movement on menu, try to increase the delay (e.g. 64).
#define LCD_ENCODER_DELAY 64 // (MicroSeconds) 1 MicroSeconds = 0.000001 Seconds (Default: 8)
//=========================== Machine Settings ==============================
#define HOTEND_NUM      1  // set in 1~6
#define EXTRUDER_NUM    1  // set in 1~6
#define FAN_NUM         1  // set in 1~6
#define FAN_CTRL_NUM    0  // set in 1~2
#define MIXING_EXTRUDER 0  // Default: 0. For mixing_extruder set to 1 (This option turns off autodetection
                           // of the number of extruders)
#define PREHEAT_LABELS   {"PLA", "PETG", "ABS", "WOOD", "TPU", "NYLON"}
#define PREHEAT_HOTEND   {200,   240,    230,   170,    220,   250}
#define PREHEAT_BED      {60,    70,     90,    50,     50,    90}
#define HEAT_MAX_TEMP    {275,       275,       275,       275,       275,       275,       150,    60}
#define HEAT_SIGN_ID     {"T0:",     "T1:",     "T2:",     "T3:",     "T4:",     "T5:",     "B:",   "C:"}
#define HEAT_DISPLAY_ID  {"T0",      "T1",      "T2",      "T3",      "T4",      "T5",      "Bed",  "Chamber"}
#define HEAT_CMD         {"M104 T0", "M104 T1", "M104 T2", "M104 T3", "M104 T4", "M104 T5", "M140", "M141"};
#define HEAT_WAIT_CMD    {"M109 T0", "M109 T1", "M109 T2", "M109 T3", "M109 T4", "M109 T5", "M190", "M191"};
#define TOOL_CHANGE      {"T0",   "T1",      "T2",      "T3",      "T4",      "T5"}
#define EXTRUDER_ID      {"E0",   "E1",      "E2",      "E3",      "E4",      "E5"}
// Prevent extrusion if the temperature is below set temperature
#define PREVENT_COLD_EXTRUSION_MINTEMP 180
 * Fan control & Fan type Options:
 *  0: FAN_TYPE_F       - default cooling fan speed (Check Marlin GCode M106)
 *  1: FAN_TYPE_CTRL_S  - Controller fan speed for stepper or hot bed ON (Check Marlin GCode M710)
 *  2: FAN_TYPE_CTRL_I  - Controller fan idle speed  (Check Marlin gcode - M710)
 *  8: FAN_TYPE_UNKNOWN - Unknown / Not defined
#define FAN_MAX_PWM      {       255,       255,       255,       255,       255,       255,       255,       255 };
#define FAN_DISPLAY_ID   {      "F0",      "F1",      "F2",      "F3",      "F4",      "F5",     "CtL",     "CtI" };
#define FAN_CMD          { "M106 P0", "M106 P1", "M106 P2", "M106 P3", "M106 P4", "M106 P5",    "M710",    "M710" };
#define FAN_TYPE         {         0,         0,         0,         0,         0,         0,         1,         2 };
// Speed/flow rate names displayed in status screen
#define SPEED_ID {"Sp.", "Fr."}  // (speed, flow rate)
// Axes names displayed in Parameter Settings menu
#define AXIS_DISPLAY_ID  {"X",  "Y",  "Z",   "E0",  "E1"}  // (X, Y, Z, E0, E1)
// Default X & Y speed (mm/min)
#define SPEED_XY_SLOW   1000
#define SPEED_XY_NORMAL 3000
#define SPEED_XY_FAST   5000
// Default Z speed (mm/min)
#define SPEED_Z_SLOW   500
#define SPEED_Z_NORMAL 1000
#define SPEED_Z_FAST   2000
// Extrude speed (mm/min)
#define EXTRUDE_SLOW_SPEED     60
#define EXTRUDE_NORMAL_SPEED  600
#define EXTRUDE_FAST_SPEED   1200
// Size of machine
#define X_MIN_POS   0
#define Y_MIN_POS   0
#define Z_MIN_POS   0
#define X_MAX_POS 235
#define Y_MAX_POS 235
#define Z_MAX_POS 250
// Is this a Delta printer
#define IS_DELTA            false
#define DELTA_MBL_Z_DROP_MM 50.0f  // MBL Drop 50mm first after home avoid crashing into the top of the towers.
// Pause Settings
#define NOZZLE_PAUSE_RETRACT_LENGTH               15  // (mm)
#define NOZZLE_RESUME_PURGE_LENGTH                16  // (mm)
#define NOZZLE_PAUSE_X_POSITION     (X_MIN_POS + 10)  // (mm) Must be an integer
#define NOZZLE_PAUSE_Y_POSITION     (Y_MIN_POS + 10)  // (mm) Must be an integer
#define NOZZLE_PAUSE_Z_RAISE                      20  // (mm)
#define NOZZLE_PAUSE_E_FEEDRATE                  600  // (mm/min) retract & purge feedrate
#define NOZZLE_PAUSE_XY_FEEDRATE                6000  // (mm/min) X and Y axes feedrate
#define NOZZLE_PAUSE_Z_FEEDRATE                  600  // (mm/min) Z axis feedrate
 * Manual Leveling
 * Move to four corner points to Leveling manually (Point 1, Point 2, Point 3, Point 4).
#define LEVELING_EDGE_DISTANCE        30  // Inset distance from bed's edge for calculating leveling point location
#define LEVELING_POINT_Z            0.0f  // Z-axis position when nozzle stays for leveling
#define LEVELING_POINT_MOVE_Z      10.0f  // Z-axis position when nozzle move to next point
#define LEVELING_POINT_XY_FEEDRATE  6000  // (mm/min) X and Y axes move feedrate
#define LEVELING_POINT_Z_FEEDRATE    600  // (mm/min) Z axis move feedrate
#define LEVELING_EDGE_DISTANCE_DISPLAY_ID "X/Y"
#define LEVELING_EDGE_DISTANCE_MIN           0
#define LEVELING_EDGE_DISTANCE_MAX         100
#define LEVELING_EDGE_DISTANCE_DEFAULT    LEVELING_EDGE_DISTANCE
// Z Fade limits
#define Z_FADE_MIN_VALUE      0.0f
#define Z_FADE_MAX_VALUE     20.0f
#define Z_FADE_DEFAULT_VALUE 10.0f
// Probe Offset limits
#define PROBE_Z_OFFSET_MIN_VALUE     -20.0f
#define PROBE_Z_OFFSET_MAX_VALUE      20.0f
#define PROBE_Z_OFFSET_DEFAULT_VALUE   0.0f
// Home Offset limits
#define HOME_Z_OFFSET_MIN_VALUE     -20.0f
#define HOME_Z_OFFSET_MAX_VALUE      20.0f
#define HOME_Z_OFFSET_DEFAULT_VALUE   0.0f
// Babystep limits
#define BABYSTEP_MIN_VALUE     -5.0f
#define BABYSTEP_MAX_VALUE      5.0f
#define BABYSTEP_DEFAULT_VALUE  0.0f
#define BABYSTEP_MAX_STEP       1.0f
 * SD support
 * Starting from Marlin Bugfix 2.0.x Distribution Date: 2020-04-27 & above, the TFT will auto detect
 * On-Board SD Card and auto-configure M27 AutoReport with M115 command.
 * Set the time interval to poll SD Printing status if Marlin reports M27 AutoReport as disabled.
#define M27_REFRESH             3     // Time in sec for M27 command
#define M27_WATCH_OTHER_SOURCES true  // if true the polling on M27 report is always active. Case: SD print
                                      // started not from TFT35
 * Bed Leveling
 * The TFT will attempt to auto detect Bed Leveing type with marlin firmware.
 * Set to 1 to enable auto-detect (Marlin only) or choose one of the options below if auto-detect
 * does not work.
 * WARNING: If you're not sure, leave on auto-detect or disabled.
 *          UBL has extra options other leveling systems might not have.
 * Options: [0: Disabled, 1: Auto-detect, 2: ABL, 3: BBL, 4: UBL, 5: MBL]
#define ENABLE_BL_VALUE 5  // Default: 1
 * TouchMI settings (on ABL menu)
 * Enable this option for settings TouchMI sensor on ABL Menu (Init, Z Offset, Save, Test).
#define TOUCHMI_SENSOR_VALUE 0  // Default: 0
// Mesh Leveling Max Grid points
// Set the maximum number of grid points per dimension.
#define MESH_GRID_MAX_POINTS_X 10  // (Minimum 1, Maximum 15)
#define MESH_GRID_MAX_POINTS_Y 10  // (Minimum 1, Maximum 15)
 * Auto save/load Bed Leveling data
 * The TFT will auto detect if BL data are available.
 * Enable this will send "M500" after "G29" to store leveling value
 * and send "M420 S1" to enable leveling state after startup.
#define AUTO_SAVE_LOAD_BL_VALUE 1  // Default: 1
// PID autotune
#define PID_CMD {"M303 U1 C8 E0", "M303 U1 C8 E1", "M303 U1 C8 E2", "M303 U1 C8 E3", "M303 U1 C8 E4", "M303 U1 C8 E5", "M303 U1 C8 E-1", ""};
#define PID_PROCESS_TIMEOUT (15 * 60000)  // (MilliSeconds, 1 minute = 60000 MilliSeconds)
 * M600, M601 ; pause print
 * PrusaSlicer can add M601 on certain height.
 * Acts here like manual pause.
#define NOZZLE_PAUSE_M600_M601
 * M701, M702 ; Marlin filament load unload gcodes support
 * FILAMENT_LOAD_UNLOAD_GCODES option on Marlin configuration_adv.h need to be uncommented.
 * Adds a submenu to the movement menu for selecting load and unload actions.
#define LOAD_UNLOAD_M701_M702
//========================== Other UI Settings ==============================
// Show bootscreen when starting up
#define SHOW_BTT_BOOTSCREEN
// Bootscreen logo time in ms
#define BTT_BOOTSCREEN_TIME 3000
// Enable alternative Move Menu Buttons Layout matching the direction of actual printer axis
// Update the icons from alternate icon folder.
#define ALTERNATIVE_MOVE_MENU
 * Friendly Z offset language
 * Replace decrease/increase and "-" & "+" icons with down/up and friendly icons.
#define FRIENDLY_Z_OFFSET_LANGUAGE
 * Quick EEPROM Menu
 * Enable EEPROM menu (save/load/reset buttons) in Settings > Machine Menu.
 * NOTE: If disabled, EEPROM operations can also be accessed in the (settings > machine > parameters) menu.
#define QUICK_EEPROM_BUTTON
 * Startup Knob LED Color (TFT28 V3.0, TFT35 E3.0, TFT43 V3.0, TFT50 V3.0 & TFT70 V3.0)
 * Options: 0: LED_OFF,     1: LED_WHITE,   2: LED_RED,
 *          3: LED_ORANGE,  4: LED_YELLOW,  5: LED_GREEN,
 *          6: LED_BLUE,    7: LED_INDIGO,  8: LED_VIOLET
#define STARTUP_KNOB_LED_COLOR 1  // Default: 1
// Keep the LED state in Marlin Mode
#define KEEP_KNOB_LED_COLOR_MARLIN_MODE
 * LCD Brightness and LCD IDLE Brightness (TFT28 V3.0, TFT35 E3.0, TFT43 V3.0, TFT50 V3.0 & TFT70 V3.0)
 * Options: 0: OFF,          1:  5 Percent,   2: 10 Percent,
 *          3: 20 Percent,   4: 30 Percent,   5: 40 Percent,
 *          6: 50 Percent,   7: 60 Percent,   8: 70 Percent,
 *          9: 80 Percent,  10: 90 Percent,  11: 100 Percent
#define DEFAULT_LCD_BRIGHTNESS       11  // Default: 11
#define DEFAULT_LCD_IDLE_BRIGHTNESS   3  // Default: 3
 * Idle LCD diming Timer (TFT28 V3.0, TFT35 E3.0, TFT43 V3.0, TFT50 V3.0 & TFT70 V3.0)
 * The LCD screen will dim to idle brightness,
 * if the display is not touched for the period of the lcd idle timer.
 * Options: 0: OFF,          1: 5 Seconds,      2: 10 Seconds,
 *          3: 30 Seconds,   4: 60 Seconds,     5: 120 Seconds,
 *          6: 300 Seconds,  7: CUSTOM Seconds
#define DEFAULT_LCD_IDLE_TIMER  0  // Default: 0
#define LCD_DIM_CUSTOM_SECONDS (10 * 60)  // Custom value in seconds. This will be used if DEFAULT_LCD_IDLE_TIMER
                                          // is set to 7 (CUSTOM Seconds).
 * Buzzer Settings
 * The duration and frequency for the UI feedback sound.
 * Set these to 0 to disable audio feedback in the LCD menus.
 * Only valid for SERIAL_TSC LCD MODE and if BUZZER_PIN is set or available.
 * NOTE: Test audio output with the G-Code:
 *       M300 S<frequency Hz> P<duration MilliSeconds>
#define BUZZER_FREQUENCY_DURATION_MS     20  // (MilliSeconds) Default: 20
#define BUZZER_FREQUENCY_HZ           10000  // (Hz) Default: 10000 (20Hz to 60000Hz)
 * Buzzer pin state when buzzer is idle or no sound is playing
 * Options: [HIGH, LOW]
#define BUZZER_STOP_LEVEL LOW  // Default: LOW
 * Toast notification duration (in MilliSeconds)
 * Set the duration for displaying toast notification on top of the screen.
#define TOAST_DURATION (3 * 1000)  // (MilliSeconds)  1000 MilliSeconds = 1 Second
 * Notification style for ACK messages
 * Set the notification style to use for displaying the ACK messages which start with 'echo:'.
 * NOTE: The OFF value is applied to any ACK message type (e.g. even to known echo ACK).
 *       It means that any kind of ACK message is silently discard.
 * Options: [0: OFF, 1: POPUP, 2: TOAST]
 *  OFF:   No notification. The message is ignored.
 *  POPUP: Display a popup window for user confirmation.
 *  TOAST: A Toast notification is displayed for few seconds. No user interaction is needed.
#define ACK_NOTIFICATION_STYLE 1  // Default: 1
// Fan speed as a percentage instead of PWM value
#define SHOW_FAN_PERCENTAGE true  // To enabled: true | To disabled: false (Default: true)
 * Mesh Editor Keyboard on left side
 * By default the Mesh Editor Keyboard is drawn on right side of the screen.
 * Enable MESH_LEFT_KEYBOARD to draw the mesh editor keyboard on left side of the screen.
//#define MESH_LEFT_KEYBOARD
// Terminal Keyboard / Numpad settings
// Terminal Keyboard / Numpad theme
// Uncomment to enable Material theme for keyboard and Numpad
//#define KEYBOARD_MATERIAL_THEME // Default: disabled
 * Color scheme for the Terminal Keyboard / Numpad
 * Options: [0: Default, 1: Invert, 2: High-Contrast]
 *  Default: The keyboard follows system background and border colors.
 *  Invert: The keyboard is drawn with background swapped with border colors.
 *  High-Contrast: Use white and black colors for high contrast.
#define KEYBOARD_COLOR_LAYOUT 0  // Default: 0
 * QWERTY/QWERTZ keyboard layout
 * Keyboard layout for Terminal Keyboard (Only for TFT70 V3.0).
 * Options: [0: qwerty, 1: qwertz, 2: azerty]
 *  default: The keyboard has an alphabetically order.
 *  qwerty: The typically keyboard Layout for english.
 *  qwertz: The typically keyboard Layout for german.
 *  azerty: The typically keyboard Layout for french.
#define TERMINAL_KEYBOARD_LAYOUT 0  // Default: 0
//=========================== Other Settings ================================
// Power Supply
#define PS_ON_ACTIVE_HIGH true  // Set 'false' for ATX (1), 'true' for X-Box (2)
 * Maximum hotend temperature for automatic shutdown after printing
 * If automatic shutdown(Auto Power) is enabled, the printer will shutdown automatically if the
 * hotend temperature is below this value. If the hotend temperature is higher than this value
 * the fans will be turned on to cool down and it will wait for the hotend temperature to drop below
 * this value before shutting down automatically.
#define AUTO_SHUT_DOWN_MAXTEMP 50
// Filament Runout Settings (if connected to TFT controller)
// Filament runout detection
#define FIL_RUNOUT_INVERTING true  // Set to false to invert the logic of the sensor. (Default: true)
#define FIL_NOISE_THRESHOLD  100   // (MilliSeconds) Pause print when filament runout is detected atleast for this duration.
// Smart filament runout detection
// For use with an encoder disc that toggles runout pin as filament moves.
#define FILAMENT_RUNOUT_DISTANCE_MM 7
// Power Loss Recovery
// Most suitable for Delta printers since most printers will crash into printed model when homing after powerloss.
// Home before power loss recovery
#define HOME_BEFORE_PLR false  // To enabled: true | To disabled: false (Default: false)
// Backup power / UPS to move Z axis on power loss
#define BTT_MINI_UPS false  // To enabled: true | To disabled: false (Default: false)
// Raise Z axis on resume (on power loss with UPS)
#define POWER_LOSS_ZRAISE 10  // (mm) Default: 10
 * Rapid Serial Communication
 * More frequent Serial communicaiton while printing.
 * Send and parse G-codes more frequently while drawing on screen to prevent printer idling and stuttering due to
 * empty printer buffer.
 * NOTE: This may slow down graphics while switching menus while printing.
#define RAPID_SERIAL_COMM
 * Custom G-code Commands
 * Support for up to 15 custom G-codes. Uncomment CUSTOM_*_LABEL and CUSTOM_*_GCODE to enable custom G-code.
 * CUSTOM_X_LABEL is the name of the custom button, CUSTOM_X_GCODE is the G-code to be sent by the custom button,
 * this should always end with a New-Line character '\n'.
#define CUSTOM_0_LABEL "Disable Steppers"
#define CUSTOM_0_GCODE "M84\n"
#define CUSTOM_1_LABEL "Init SD Card"
#define CUSTOM_1_GCODE "M21\n"
#define CUSTOM_2_LABEL "Release SD Card"
#define CUSTOM_2_GCODE "M22\n"
#define CUSTOM_3_LABEL "Enable Leveling State"
#define CUSTOM_3_GCODE "M420 S1\n"
#define CUSTOM_4_LABEL "Save to EEPROM"
#define CUSTOM_4_GCODE "M500\n"
#define CUSTOM_5_LABEL "Restore from EEPROM"
#define CUSTOM_5_GCODE "M501\n"
#define CUSTOM_6_LABEL "EEPROM Defaults"
#define CUSTOM_6_GCODE "M502\n"
//#define CUSTOM_7_LABEL "Custom7"
//#define CUSTOM_7_GCODE "M105\n"
//#define CUSTOM_8_LABEL "Custom8"
//#define CUSTOM_8_GCODE "M105\n"
//#define CUSTOM_9_LABEL "Custom9"
//#define CUSTOM_9_GCODE "M105\n"
//#define CUSTOM_10_LABEL "Custom10"
//#define CUSTOM_10_GCODE "M105\n"
//#define CUSTOM_11_LABEL "Custom11"
//#define CUSTOM_11_GCODE "M105\n"
//#define CUSTOM_12_LABEL "Custom12"
//#define CUSTOM_12_GCODE "M105\n"
//#define CUSTOM_13_LABEL "Custom13"
//#define CUSTOM_13_GCODE "M105\n"
//#define CUSTOM_14_LABEL "Custom14"
//#define CUSTOM_14_GCODE "M105\n"
 * Start/End/Cancel G-code
 * G-code that runs after a print starts, ends, or canceled.
 * Enable Start & End G-code in SETTINGS -> FEATURE menu.
// Start G-code - run this G-code before starting print
#define PRINT_START_GCODE "G28 XY R10\n"  // Raise Z 10mm before homing X & Y
// End G-code - run this G-code after finishing print
#define PRINT_END_GCODE "G90\nG1 E-4\nG92 E0\nM18\n"  // Switch to absolute positioning, reduce filament pressure by
                                                      // performing small retract, reset extruder position, disable steppers
// Cancel G-code - run this G-code after canceling print
#define PRINT_CANCEL_GCODE "M104 S0\nM140 S0\nG28 XY R10\nM107\nM18\n"  // Home XY and raise Z 10mm
#endif
Re: Project CTC A13
Bericht door wim62 » 08 jun 2021, 14:21
Voor dat tft scherm hoefd je geen apparte firmware te installeren .
In marlin gewoon fulltime grafic reprap selecteren .
In die geest .
Re: Project CTC A13
Bericht door Rob52 » 08 jun 2021, 14:28
Dat kan maar dan is het standaard. De firmware is inderdaad wel voor geïnstalleerd. Wil je het naar eigen wensen aanpassen dan moet je er wel wat meer aan doen. Je kunt er bijvoorbeeld eigen knoppen met eigen functies of voorverwarming aan toevoegen. Of de icoontje personaliseren en de taal aanpassen. Maar er zit nog veel meer in.
Re: Project CTC A13
Bericht door PrintEngineer » 08 jun 2021, 15:04
In principe kan ik het alleen zelf fout doen. Zowel mainboard als TFT zijn van dezelfde fabrikant en die zal er toch wel voor gezorgd hebben dat het plug en play kan werken. Het enige is dat ik een absolute beginner ben in het configureren van Marlin. Dus ik zal daar inderdaad nog wel wat moeten doen om het aan de praat te krijgen. Via Cura krijg ik wel gewoon de temperaturen binnen en kon ik het hotend ook al naar 200°C sturen. De verwarming voor het heatbed is niet aangesloten maar ik verwacht wel dat die ook gaat werken
Re: Project CTC A13
Bericht door Rob52 » 08 jun 2021, 15:19
wim62 schreef:
08 jun 2021, 14:21
Je moet voor de Marlin mode deze hebben
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
Voor de touch mode wordt dit door de TFT zelf via de seriële poort geregeld, daar hoef je het niet voor in Marlin te installeren.
Re: Project CTC A13
Bericht door PrintEngineer » 08 jun 2021, 15:37
Rob in welke file kan ik die setting vinden?
Re: Project CTC A13
Bericht door wim62 » 08 jun 2021, 15:43
08 jun 2021, 15:19
wim62 schreef:
08 jun 2021, 14:21
Ja die bedoelde ik , ik was aan het werken zodoende zij ik ook in die geest .
Re: Project CTC A13
Bericht door Rob52 » 08 jun 2021, 16:53
PrintEngineer schreef:
08 jun 2021, 15:37
In Marlin configuration.h
//=======================   LCD / Controller Selection  =======================
//=========================      (Graphical LCDs)      ========================
// CONTROLLER TYPE: Graphical 128x64 (DOGM)
// IMPORTANT: The U8glib library is required for Graphical Display!
//            https://github.com/olikraus/U8glib_Arduino
// NOTE: If the LCD is unresponsive you may need to reverse the plugs.
// RepRapDiscount FULL GRAPHIC Smart Controller
// https://reprap.org/wiki/RepRapDiscount_Full_Graphic_Smart_Controller
// Note: Details on connecting to the Anet V1.0 controller are in the file pins_ANET_10.h
Re: Project CTC A13
Bericht door PrintEngineer » 08 jun 2021, 21:16
Het is gelukt om de TFT35 naar een nieuwere versie firmware te upgraden, maar nog steeds zie ik geen actuele waarden in het display. Dus moet het wel liggen aan de SKR 1.4 turbo firmware of een jumper setting die ik nog moet maken. Maar vooralsnog is het niet mogelijk om de printer te bedienen met het TFT scherm. Het display meld zelf ook "no printer attached"
Re: Project CTC A13
Bericht door Zappa » 08 jun 2021, 21:24
Staan de Baudrates van display en mb hetzelfde? Was bij mij in het begin niet het geval, met als resultaat dezelfde melding op het display.
Printer 2: ToRo mkI (omgebouwde Wanhao D9 400)
Overig: Palette 2
SW: Fusion360, S3D
