Cube 3D printer
Admin
Site Admin
Cube 3D printer
Bericht door Admin » 31 aug 2012, 17:32
De met de American Technology Award beloonde Cube is een betaalbare en compacte 3D thuisprinter. Met een prijs van $1,299 een van de goedkoopste van dit moment.
Website link: http://cubify.com/cube/
  • The Cube has a print space of 5.5" x 5.5" x 5.5". To see what you can make browse the 25 files you get with the Cube, or have a look in the store.
  • The Cube works with color cartridges, one for each color. We've selected a range of 10 colors to use with your Cube.
  • 3D printing with the Cube is easy. Send your prints to the Cube from your computer.
  • The Cube ships with easy to use software that turns all your downloaded models or self-made models into files the Cube can understand.
  • With our EZ load Cartridge changing to a different color or replacing an empty cartridge is a breeze.
Cube 3D Printer Specs
Cube Dimensions:
without cartridge
10 x 10 x 13 inches - 26 x 26 x 34 cm
Cube Weight:
without cartridge
9.5 lb - 4.3 kg
Box Dimensions:
16 x 15 x 19 inches - 41 x 38 x 48 cm
Box Weight: 19.0 lb - 8.6 kg
Connectivity
Wireless:
802.11b/g with:
WPS Infrastructure
Adhoc Mode
Requirements:
Cubify Client Software
(supplied with the Cube)
USB stick, to transfer print files
Technology:
Plastic Jet Printing (PJP)
Print Jets:
Single Jet
Max creation size:
5.5 x 5.5 x 5.5 inches
14 x 14 x 14 cm
Material:
Tough Recyclable Plastic
Layer Thickness:
10 mil | 0.01 inches
250 microns | 0.25 mm
Supports:
Fully Automated
Easy to peel off
Cartridge:
1 Cartridge prints 13 to 14 mid-sized creations
Software
Description:
Comes with software to create .CUBE print files.
Windows Requirements:
Cubify Client runs on 32 and 64-bit Operating Systems.
• Windows XP Professional or Home Edition with Service Pack 3
• Windows 7
Windows & is required for ad-hoc WiFi Print Job submission.
If not already installed, the Cubify Client installer will automatically install the Microsoft .NET 4.0 Framework
Minimum Hardware Requirements:
A PC with these minimum requirements will be required to run the Cubify Client Software
Processor: Multi-core processor - 2GHz or faster per core
System RAM: 2 GB
Screen Resolution: 1024x768
Warranty
90 days parts and labor.
NielsE
Re: Cube 3D printer
Bericht door NielsE » 22 nov 2013, 19:30
Er zijn op dit moment wel beter 3d printers op de markt!
Ondanks dat de prijs wel heel erg aantrekkelijk is, betaal je toch maar 200, 300 euro extra voor een erg goede 3d printer.
Admin
Site Admin
Re: Cube 3D printer
Bericht door Admin » 22 nov 2013, 21:15
Je hebt gelijk. Dit topic is al weer gedateerd. De Cube was een tijd geleden een erg betaalbare desktop 3d-printer. Inmiddels niet meer. Zo snel gaat het allemaal....
Ik zou zeggen, post gerust wat printers die je zelf interessant vindt! Ik ga zelf ook nog eens kijken of dit wat actueler kan. ;)
Misschien een goed idee om een topic te openen over de goedkoopste 3d-printers?
rdwrt
Re: Cube 3D printer
Bericht door rdwrt » 02 okt 2017, 12:57
Zo, is dit even een oud topic! In een makerspace in Delft heb ik de 3D printer afgestoft, het bleek een Cube.
Hij doet het nog met de bijgeleverde cartridge, dus dat is alvast wat!
Nou wordt het spannend, cubify is niet meer actief op de consumer markt, dus ik zoek aftermarket-cartridges op eBay.
Daarvoor moet ik weten of het een Gen1 of Gen2 printer is. Heeft iemand enig idee waar ik dat aan kan zien? Er staat niks op over de generatie, dus ik denk aan gen. 1. Ergens heb ik gelezen dat de gen 1. alleen PLA kan printen terwijl op de doos staat dat hij zowel PLA als ABS kan verwerken.
rdwrt
Re: Cube 3D printer
Bericht door rdwrt » 02 okt 2017, 13:11
Ok ik geloof dat ik hem doorheb. De 1e generatie heeft een heated bed uit donker metaal maar kan alleen ABS printen. De 2e generatie heeft een glazen bed, niet heated, en kan ABS en PLA printen.
Gdk3dfilamenten
Re: Cube 3D printer
Bericht door Gdk3dfilamenten » 04 okt 2017, 09:30
hee rdwrt,
Als mede delftenaar leuk te zien dat maakbaar ook bezig is met 3D printen;)
Wat ik ook nog wel het vermelden waard vind, is dat er momenteel sommige ABS varianten op de markt bestaan, met zoveel toevoegingen erin (modifiers) dat deze dezelfde eigenschappen vertonen bij printen zoals PLA (zelfde smelt traject, zelfde krimp ratio etc).
Met dit ABS, kan dan op ELKE printer waar PLA op geprint kan worden, ook gelijk ABS op geprint worden.
Ook vind ik dat PET vergelijkbaar print als PLA, en dus altijd geprint kan worden, net zoals PLA, echter zie ik deze niet vaak staan bij de beschikbare materialen die de printer fabrikanten opgeven.
Hecht dus door bovenstaande redenen niet teveel waarde aan wat de fabrikant als materialen opgeeft, maar kijk dus met name naar de max temperaturen van nozzle (en evt bed), het printbed materiaal (tegenwoordig vaak glas, of adhesi zoals buildtak) en of de printer een omsloten omgeving heeft.
Let wel dat indien de temperatuur niet te veranderen is, door bijvoorbeeld gesloten software omgeving, je helaas aan bepaalde temperaturen gebonden bent.
Misschien is het voor jou het makkelijkst als je lange tijd van plan bent om te gebruiken, om te kijken naar methodes om de chip in de cartridge te hacken, zodat je ook andere filamenten kan gebruiken?
Als je vragen hebt over de printer hoef je maar berichtje te plaatsen, wellicht kan ik je bij sommige dingen helpen;)
Groetjes, Ewoud
Richvdijk
Re: Cube 3D printer
Bericht door Richvdijk » 15 okt 2020, 21:29
Beste mensen.
Ik heb een cube1 kunnen overnemen van iemand via marktplaats. Dit zijn ook gelijk mijn eerste stappen in de wereld van een 3d printer thuis. Nu loop ik tegen het volgende probleem aan dat ik geen van mijn tekeningen kan printen omdat de software die ik heb het omzet naar een cube3 bestand en die kan de printer niet gebruiken. Ik hoop dat er iemand is die mij kan helpen.
Met vriendelijk groet,
Richard van Dijk
Re: Cube 3D printer
Bericht door Frits » 16 okt 2020, 07:19
Dan zul je toch eerst even moeten vertellen over welke software je het hebt.
Cura 4.7
Artillery Sidewinder X-1 v5
Richvdijk
Re: Cube 3D printer
Bericht door Richvdijk » 17 okt 2020, 21:00
Ik he op mijn pc de software cube print 4.03 staan.
Als ik iets wil printen via die software dan moet ik de file opslaan op een sd card. Tot zover gaat het goed. alleen het bestand word opgeslagen als een cube 3 bestand. En de printer kan die dan weer niet vinden terwijl ik zeker weet dat deze op de sd card staat. Verder had ik gedacht dat een stl file ook wel door de printer gelezen kan worden maar ook die ziet de printer niet.
Vandaar dat ik het vraag. hopelijk heeft een van jullie een oplossing. Anders ben ik bang dat ik een verkeerde koop heb gedaan.
Met vriendelijke groet,
Richard
nwpvr
Re: Cube 3D printer
Bericht door nwpvr » 17 okt 2020, 23:40
Ik ken de printer verder niet, maar dat maakt het natuurlijk niet minder interessant. Nu is er niet zoveel meer over deze toch wel gedateerde printer te vinden.
Om nu te zeggen of het een verkeerde aankoop is, weet ik niet. Tegenwoordig zijn de open source 3D printers zoals een ANET of Creality populairder en derhalve is daar ook veel meer troubleshooting voor te vinden.
Ik ben nog geen 3Dprinters tegengekomen die rechtstreeks een STL kunnen printen. Een STL bevat namelijk enkel het 3D model en geen printgerelateerde settings zoals bijvoorbeeld de temperatuur waarmee geprint kan worden. Je hebt daarom een zogeheten slicer nodig; software die het STL model kan slicen (laagjes maken) en voorziet van allerlei settings en instructies waarmee je printer uit de voeten kan. Dit is tegenwoordig in zogeheten GCode: Een tekstbestand met allerlei commando's.
Een (korte) zoektocht (http://infocenter.3dsystems.com/cube/us ... r-creation) levert inderdaad op dat deze printer enkel kan werken met .cube3 files: Een eigen fileformat en dus niet zomaar GCode. Daarom heb je de bijgeleverde software ook nodig en ben je daarvan dus ook afhankelijk om je STL om te zetten naar een printerbestand.
Dat hoeft overigens allemaal nog niet zo'n probleem te zijn. Open Source of Closed Source.. het heeft beiden voor- en nadelen.
Je hebt in elk geval de software die deze bestanden kan genereren dus dat lijkt me goed te gaan.
Heb je de SD card als eens geformatteerd? Een tip zou kunnen zijn om eens te letten of deze als FAT32 geformatteerd is. Windows formateert met zijn eigen tool vaak in exFAT. Dit kan problemen geven, zeker bij wat oudere apparatuur. In zijn algemeenheid kunnen andere indelingen kunnen nog wel eens problemen opleveren.
Een suggestie voor een goede formattool voor FAT32:
http://www.ridgecrop.demon.co.uk/index. ... format.htm
Een andere optie: Als ik het allemaal goed begrijp kan de printer ook via de wifi aangestuurd worden?
Groeten,
Niels
- Ender 3 V2
- Anet A8 Plus met modificaties
- Cura
- Octoprint
